John Deere LT 155 no start
ICutGrass
Hello, I have An older lt155, and it will
Not start, turnover, click, or anyting! And yes the battery is hooked up.
Last summer, I was cuttin my grass, went to fuel up, put the park break on to it would stay running, but when I got off the seat it died. I never thought much of it. When I
Got back on and tried to start it would not
Do anything for me! If I unplug the seat and petal safety switches will that disable them?
I am
Not sure where to start. Thanks
-Justin
Are you getting 12 V at the small wire on the solenoid with the key in the start position. if yes then most likely solenoid problem. If not unplug the pedal switch and see if you are getting 12 v there with the key in start position. If yes then test the pedal switch, which I think is were the problem will be. keep working your way back to the key switch, and you will find the problem.
I believe the pedal switch in part of the start circuit, so it will need to stay plugged in to start the mower.
ICutGrass
Alright!! It's alive! I don't even wanna tell you what it was, everyone will make fun of me!
Buuuttt now I have another issue, when I go to engage my deck, it shuts off.
And just as I was typing this I realized I can likely just tape the sensor switch in, so the mower things its disengaged.. Hmm
