John Deere L110 deck replacement
michealmyers
Question for you guys I have a L110 and I found a deck from an L120 for sale, will this fit the L110?
The L110 is a 42" and the L120 is a 48"
mjb8fj
fits/mounts up, yes. But your 110 has a manual engagement to turn the blades on, vs the 120 which has an electric pto
The deck is no problem.
They both have the same mounting bracket for the belt tensioning.
On the electric PTO it is a short length of cable with a spring on it
On the manual one it is a cable.
The 44" deck will have different sized pulleys on top of the spindles ( should be bigger ) if it is a 2 blade deck or smaller if it is a 3 blade deck.
The deck belt most likely won't fit either.
