john deere hydro 175
SMG58
picked this tractor up for free , got it running but every time had to spray carb to get going then ran fine. took carb apart looked cleaned reinstalled now will not run at all. You can spay directy into intake and back fires. Good spark , compression any ideas ? Are these carbs prone to going bad ? Plenty of gas from fuel pump as well. Thanks for any advice
The Wing Foo Far engine is prone to fading away.
The Ding Dang Dong engine rings its neck off
However the carbs never give problems.
You are our eyes ,ears & hands.
You can see what is on you shed floor, we can't.
We can not fix what we can not see.
Some more information for the blind ?
What he is saying is we need tractor and engine model numbers.
