John Deere GX75
okiepc
I am new here with a question. I have a very nice, though be it older, JD GX75 electric start mower & here is my question, is it possible to check or change the transaxle fluid, I find no mention of it in my owners repair manual. The reason for the question is, I maintain all of my cars & equipment and transmission fluid changes are mandatory to keep things up and running.
Thanks for any input
KennyV
Welcome to LMF...
You are right ... all things with lube should be serviced regularly...
Some are easier than others & some are seemingly imposable, moisture and just normal shearing of oils and greases are reasons to drain and replace all fluids...
That is a nice RER mower... I would find a way to service everything on it... :smile:KennyV
