RidingE130
- Jun 9, 2023
- 2
Mower has under 50 hours is over a year old. It stalled out right by the cover Its covered with. I pushed a few feet and thinking it was out of gas I waited a week 10 days until grass need cutting again. I filled it up with just a half gallon tried to start nope. Checked the fuel pump and filter pump seems to be pumping but slow for me a guy that mostly works on cars I took the air filter off was a little dirty so I pulled it off and the spark plug to check looked OK. Replaced plug tried to start with air filter off still wouldn't start. So I tried putting a small amount of fuel in the air intake it started for a moment then died. I'm about to drain the carb and see maybe bad gas got into it somehow that's what stalled it originally IDK any help appreciated
