John Deere D100
bramsey46
I was using my mower last week and was in reverse. I forgot I was in reverse and engaged the blades and the mower cut off as it is designed to do. Since then, I have not been able to get the mower to start. There is power to the mower (lights work) but the engine will not even turn over. Does anyone have any idea what the problem could be?
I'm not that experienced with ride on mowers, but if all the switches and stuff are in the right position, and it still won't crank over, you may have blown a fuse or relay that goes to the starter motor.
