john deere 68 coil wiring
moody34
Hi. Just acquired a 68 and will not start. It's a pull start. There is no spark, fuel is being fed. Ignition coil or the neutral safety is the culprit. I'm gonna change both just to cover bases. jd68 ignition coil wiring.jpgjohn deere 68 ignition coil wiring 1.jpg
Question is, what is the second wire coming from underneath the coil then disappearing under the flywheel. One of the wires connects to one of the mounting bolts with an eyelet, the other one does the disappearing act. How would i go about swapping coils? I can cut and put a butt connector if necessary but don't want to do that. Please help.... thanks
reynoldston
The model 68 JD came with a 8 HP Briggs engine. The original ignition came with points and condenser which are located under the flywheel. I have found most of them have been converted over to the pointless system. You will have to remove the flywheel and replace the points and condenser which I have found its getting hard to find anymore.
Your engine has points. you can try replacing the points and condensor, but I have found that most still don't operate even after changing those, and still have to convert to the pointless ignition module.
Rust takes a toll on the module laminates causing failure.
EngineMan
Post up the engine numbers and type.
moody34
Thanks for the responses guys. image.jpgimage.jpg.
Here's a couple more pictures with the serial number involved. In the owners manual it doesn't get real specific it just says briggs and Stratton 8 hp. What is involved in the pointless conversion iLENGINE? Thanks
Thanks for the responses guys. View attachment 25844View attachment 25843.
View attachment 25845View attachment 25846
Buy the ignition module.
Remove the wire from the coil that goes to the points and the wire that goes to the ignition cut out.
Join both of these wires together then connect to the module.
The hardest part is deciding where to mount the module.
It must have a good earth and get some breeze or it will overheat.
The usual spot is one of the coil mounting bolts,
EngineMan
The single wire coming from under the flywheel would be part of the stator assembly (alternator d.c)
moody34
Could you post up the part number for the ignition module I would need? Thanks
reynoldston
That model JD 68 the engine is enclosed and you will find the module will ten to overheat on warmer days. Just buy a new set of points and condenser. It will be cheaper, easier, and the mower will start better on the warm days with a hot engine. Its a old mower that doesn't turn very sharp and it is hard to find parts for anymore so how much do you want to spend it. Most of the model 68's have just a pull rope starter.
EngineMan
Reynoldston is giving you good advice.
