Hi,
I'm trying to disassemble the augers and drive shaft from the housing of a JD 522 snowblower. I've removed the side panels to release the auger shaft on each side. The main drive shaft that goes through and connects to the rear pulley is giving me problems. I've removed the pulley and bearing shield but it seems the shaft is seized in the bearing. It rotates free and smooth. I've applied generous amounts of penetrating lube and let it sit over night. Should I use a 5lb hammer to try and free it? Any other suggestions would be well received. Sorry I don't have pics to clarify. Thanks
