john deere 345
rogerac
I have a 345 that leaks fluid around the shift rod, may also be called hydro control. It appears the case will need to be split to replace the seal/packing. If we open the case will parts fly out? We have pretty good mechanic skills, is this something we may be able to do ourselves. Thanks
