I picked up this JD 245 with a blown 14HP FC420V. The motor had thrown a rod and wrecked the case, piston and everything inside.
I bought a spare FC420V on ebay that was missing the flywheel, stator, coil, ignition module and carb. I swapped everything from my motor over to the new motor and cranked it over. It started pretty easy, no smoke, sounded great! I let it warm up and then shut it down to finish installing the rest of heat shields and hood.
The next time I tried starting it, it was a little harder to start. Then it got progressively harder to start, and it started to backfire out of the exhaust and carb. Massive gunshot type backfires. I did manage to get it running and mow a 1/2 acre lot. It ran fantastic! Just hard to start.. and now it won't start at all.
After doing a bit of research this is what I've done so far:
I am wondering, where there different flywheels for the FC420V that might be throwing the timing out?
Could a bad coil cause these backfires?
How do I test the ignition module? I'd rather not just throw parts at it, if I can avoid it.
- I found it's common for the key to sheer and the timing to be off. So I pulled the flywheel to make sure the key didn't get pushed down when I installed it. Its in its place as expected.
- Set the valves to .006 when cold.
- Checked the compression and it's right around 120psi after a few cranks.
- Spun the pushrods around to make sure they weren't bent, they look fine.
- Checked spark, it seems okay. I mean, it's there. Not sure how strong of a spark it is.
- Cleaned the coil pickup and flywheel magnet
- Swapped spark plugs
- Checked coil resistance, both sides of the coil were SLIGHTLY out of spec, low. I confirmed with two Ohm meters.
- I couldn't determine if the ignition module was bad. The service manual is kind of fuzzy how to check this.
- Pulled the carb and cleaned and inspected it. It wasn't dirty at all.
