Having some trouble with my fuel pump on a JD 165 Hydro; I have vacuum but am getting no gas to pump or even to carb... Purchased new pump from JD dealer; installed it and nothing so I ran the inlet line to the pump from a gas can and still it will not pump gas. There is vacuum coming from the motor to the pump; but it is a small amount, maybe 3-4psi ... any suggestions? I'm at my wits end... this is the fb460V motor. Thanks in advance!
