Jeking and belts breaking (Sears ZT 7000)
boabyhorseback
Hello all,
New to the forum and looking forward to some much needed help. :smile:
Sears Craftsman ZT 7000 Zero- Turn Rear Engine Rider w/ Electric Start
Briggs & Stratton
Model = 40H777
Type = 0242E2
Code = 040617YG
Motor Mfg: Briggs & Stratton
Horsepower = 22
Size = 50" Mower
USAGE:
Mow approx 1 to 1.5 acres grass every 7-14 days depending upon the season. Do not mow when grass is wet. Mower deck blade side is cleaned, sprayed with deck spray, oiled and greased on a regular basis. Mower is serviced for all filters and oil change once a year.
ISSUES:
-Belts breaking frequently. The Mower Drive Belt has broken three times within a short period of time. The most recent lasting only 2.5 months. Arbor belt has broken once.
-When I engage mower forward, with or without blades engaged, it is jerking, just like a stick shift car if you let the clutch out too fast. Even when I ease slowly forward, it still jerks. Any ideas?
-I am on my third battery within 18 months. It seemed as though the battery was being pulled down within one or two mowings, then had to be charged to start. Eventually it would not hold a charge. It would not hold proper cold cranking Amps. This last battery has not had that problem. What are the chances I got two bad batteries in a row vs. a problem with the mower pulling battery down?
Thanks in advance,
-Michelle
BlazNT
Does it do it in reverse.
mustang
jerks some in reverse but not nearly as mush as going forward
mechanic mark
Results Your engine manual & parts list, post craftsman model number from under seat, thanks.
mechanic mark
Manual Craftsman Rear engine rider ZT7000 | SearsPartsDirect Your owners manual & parts list, see troubleshooting section.
Remove your deck, hands on, & inspect everything, all pulleys, especially idler pulleys for worn out bearings, this includes deck & underside of mower, inspect hardware as well, now is a good time also to lube & grease entire mower, be sure to use OEM parts. Let us know how it goes.
