JD Z930M Loss of power right side trans
ddorrer
I have a Z930M ZT just out of warranty by two weeks. 140 hours. Right HST is loosing power both fwd and reverse. Changed oil and filters, no difference. Any ideas?
Simple term. HST = Hydro Static Transaxle (transmission).
Check drive wear since the RH is only by a small of the pulley; otherwise, it is a hydro failure. $$$ Usually will need at least the center section replaced.
