Won't start. Found fusible link broke to ignition. What size fuse do I need to fix it?
B bigman Forum Newbie Joined Oct 5, 2014 Threads 1 Messages 1 Oct 5, 2014 / JD stx38 #1 Won't start. Found fusible link broke to ignition. What size fuse do I need to fix it?
ILENGINE Lawn Royalty Joined May 6, 2010 Threads 51 Messages 11,275 Oct 5, 2014 / JD stx38 #2 Most riding mowers take either a 15 or 20 amp fuse, but consult your owners manual to be sure that you install the correct size fuse.
