JD RX75 engine surges when no load
jgayman01
I have a JD RX75 with a 9HP Kawasaki engine. It starts easily and runs okay except the engine surges at all throttle positions when there is no load. If I start driving up hill or engage the mower deck the engine runs smooth. But as soon as I push in the clutch or go down a grade the engine starts surging.
Does this sound like a carb adjustment or something going on with the governor?
Any recommended corrective actions?
Thanks!
Fish
Sounds like a bit of water sitting in the bottom of your fuel system. Just keep running it, it will likely burn it on through....
