JD LT155 losing power going forward
NoTTD
Runs fine going backward. Began losing power going forward and now will only crawl. If it was a car, I'd say the clutch was out.
I'm only the shadiest of shade tree mechanics, so what should I look for?
Thanks in advance.
mechanic mark
Replace drive belt after removing deckhttp://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dlawngarden&field-keywords=drive+belt+for+john+deere+lt+155: Shop around after getting old belt off making sure part number matches using oem belt.
Service Mower Just tractor information.
How do I adjust the drive belt tension on a John Deere LT155 Don't log in just read.
LT155 belt diagram - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
https://www.google.com/webhp?source...TF-8#q=adjusting traction drive belt jd lt155 NIB John Deere Traction Drive Belt M126009 LT155 LT166 Engine to Transmission | eBay
NoTTD
Thanks for the input re the drive belt.
Can anyone point me to instructions or a video on replacement?
