jd gt262 fc540v replacement motor
rsjr
hi i have a john deere gt 262 with a kawasaki fc540 v motor that has a bad rod knock in it can i put a kawasaki fh491v in it as a replacement motor
Yes.
It will be down a little on power.
Check the spark coil as JD used an electronic advance to get a better power response form the engine.
If they both have a single small wire then direct swap.
If the mower has a 3 wire one then the entire ignition will have to be swapped over.
