JD AM130318 radiator for an F911 mower
buzzzmeister
Looking for an unmolested AM130318 radiator. Not looking for a radiator with the 4 mounting tabs broken off as I already have that.
buzzzmeister
I'm trying not to pay $450+ for that radiator if I can help it.
A real radiator repair shop should be able to sort that out and make his repair a lot stronger than the original part.
And while he is there most likely pull the tank off and rod the grills so it works properly when refitted.
mechanic mark
Absolutely, at probably half the cost of a new radiator.
