JD 425 engine
wkd
My right hand coil is not getting a pulse from the pulse coil, what tests can I run? TIA
Only a resistance test to confirm the coil is intact and neither open or short circuited.
Both should read the same.
Check the wiring between the pulser coil and the ignition module.
The pulsers only put out 1 V AC at best so a very small amount of corrosion will kill the signal.
