JD 345 FC590V valve adjustment procedure
cliffblue
What are the specs and procedure for adjusting the valves on a 95 JD 345 FC590V? What is the torque for the valve cover bolts? Thanks in advance< Cliff
cliffblue
Hey rivets, i am just now trying to open the link you sent because my parts should be here soon. I can't read it when it is opened. what program do I need to read it? Thanks, Cliff
It is in PDF form, so you should be able to open it with just about any program. I just use my browser.
cliffblue
Thanks, I had forgotten I had removed adobe. When I reinstalled it, it opened right up. I found a link for the FC590V. Thanks again, Cliff
