If you look in the back of the machine, on top of the transmission you will see a lever you can push down. You will have to hold down on that lever as you roll the machine. These machines don't roll very fast. Hopefully the release isn't seized. The best way is to have one person hold the lever down and the other person push the machine. I have already wrapped a bungie cord around the lever to hold it down so I could push the machine myself. (I work at a dealership and sometimes have to load them myself at customers' houses)
