Hi,
I'm having some issues with putting 30" deck on JD130. Looks like some parts are missing like the front two brackets that hold and level cutting deck. Also, deck belt tension roller...where is it go exactly? Does the Vee-belts "V" part rides in it or the back of the belt? Maybe you could hook me up with a 30" deck diagram and belt routing? Thanks in advance!
