Export thread
JD 125 Rear axle play
#1
T
townhalllori
The other day I noticed about 1/2 inch of play between the rear axle and wheel. I jacked the rear of the mower up and could freely slide the wheel back and forth on the axle on one side about 1/2 inch, the other side was fine with no free play. Is this normal, or is it something that needs to be repaired.
Thanks!
#2
J
Jack17
Most likely a nylon spacer fell out. Easy fix. Good luck.
