Hi, mower is surging so I check fuel line, filters and plug. Opened the back cover and noticed the belt is really loose. In fact the entire unit is easy to move by hand. Is this correct or how is it to be. Appreciate the guidance on finding a fix. 5 hp 4 stroke Briggs, self propelled 14SZ.
http://bionicengineering.net/media/JD_14SB/JD_14SB_Technical_Manual_Tm-1471.pdf make sure governor spring is attached left side of engine as well as governor arm bolt is tight & secure. You may need to remove carburetor & purchase correct rebuild kit & install after cleaning carburetor with carburetor cleaner. Also check air & fuel filters for replacement. For safety remove spark plug boot before working on engine.
Great advice, a remaining question on this, should the belt be loose as shown in the attachment ? Also, the pullley and housing are loose to the touch. I can't identify and bolts to tighten the housing nor the belt. Thanks
