was sweeping my garage floor after going through the carb on the below husky with the below briggs intek twin. found the below red oring on the floor, no idea what its off of. does it look like anything off the carb? I took the linkages, carb bowl, float, needle, plastic fuel transfer tower apart. i did not remove the main jets or the fuel solenoid. i know the oring between the float bowl and transfer tower is present.
