Intermittent Blade Clutch
lmf2
I have a older Scag walk behind manual start mower. If I have been mowing for a while and turn off the blades they will not turn back on. After the mower sits for a couple of hours, if you start it back up they work fine until the mower warms up and you shut them off. Any ideas?
you may need to adjust the air gap between the electric coil and the clutch disc in the electric clutch. Most are set at .012 inch
