Export thread
intek 24 governor speed
#1
D
DixyKnocker
so I ended up buying a intek 24hp to swap out the windowed kohler CV22 on the dixie chopper
I know b&s sells various governor springs its currently got a 3600 on it the dixy spec CV22 turned 3700 and change before it decided to snap a rod right clean in two for no good reason
was thinking about just putting the purple 3800 rpm spring on there
I know people that race these motors and turn 7k on stock rods so I know the rods can take it its only _200_rpm
thoughts ?
#2
T
Tinkerer200
Well I would not increase the top governed speed for several reasons one being if this is a new engine you may void the warranty. Before I did anything like that I would double check the maximum blade tip speed of present set up against safety specks. I do not know of any B&S recommendation of exceeding 3,600 except for some generators.
Walt Conner
#3
B
And the stock rods will not take 7000 rpm for very long, ask any one who builds race engines.
These is no benefit from spinning the engine faster in fact a lot of hydro pumps will be damaged or just wear out prematurely if over reved.
If you want the blades to spin faster change the clutch for one with a bigger pulley
#4
D
DixyKnocker
motor is a used plant we got the entire tractor for 200 bucks
the Dixy SPEC CV22S was spected to turn 3750rpm which is why I was asking
#5
B
Then 3800 it is
