installed new governor spring and still, engine doesnt respond
rigoletto
  • / installed new governor spring and still, engine doesnt respond
People,
Popped on a new spring thinking the old one had to be the culprit, but when I slide the engine speed lever cable to run HIGH, engine does not change rpm's. I manually did get it to rev up when I gently move the lever that the spring is attached towrd the front of engine, and there doesnt seem to be ant obstruction, but when I try the lever cable again, no change. Could it be the other (small) spring?
Thanks
Are you talking about a Ford, Porsche, Briggs or Kohler? Post more info or we can't help.
rigoletto
thanks, riv, it is a B&S engine (this forum is for B&S, right?). But I should include addl info for sure, it is on a Poulan push mower, from 1997 or so, I recently started a thread o week ago or so, maybe I can pull it up for reference/moreinfo.......let me see.......
pugaltitude
You need to get rid of the cable and lock off the lever.
The engine is designed to run at approx 2900 rpm fixed speed.
Post a picture would be easier to explain.
I agree with pug, this engine is designed to run at a fixed speed. I doubt the engine will run to good if you try to change it. You have no adjustments or jets to allow for different engine speeds.
rigoletto
Hmmmmmm, (holding forehead in left hand, left elbow on desk), since day 1 in 1997 or so, the engine DID react to faster/slower speed with lever movement. Im original owner. otherwise, why would they have engineered the dumb lever/cable?
Thaks again, in helping to solve this mystery.....
rigoletto
Then why is there a governor spring?
To retain a constant preset speed and stop over revving.
rigoletto
thhaks. still dont get why it has a speed lever, and why in the past I was able to use it . Oh well, have no choice, cant get it to respond, will just push it as speed engine revs.
