info & question
tree352
Hello, my name is Teresa and I have an Ag long tractor ( purple ) and a swisher trim and mow.
Can I make the trim & mow a battery start? not strong enough to pull to start. and no one to help get it started ( Husband passed away )
cpurvis
Anything can be done if you're willing to spend the money to do it. Whether it's cost effective or not is another matter.
Without seeing your situation, I'm going to guess that a replacement engine with electric start might be the most viable option.
But there comes a time when maybe the best thing to do is transfer the mowing and upkeep of the mowing machines to someone else? Just something to consider.
If you think going the electric start route is your best option, please post engine make and model information. A few pictures wouldn't hurt, either.
Catherine
LawnWorld Support
Hi Teresa. Welcome to the forum! :welcome:
I'm going to move this thread over to Build-it Yourself section.
gasjr4wd
I've seen guys use a drill to start engines... put a socket driver in the drill and use the nut on top of the engine.
Lena01
thanks for all your posts .. i like this web site
