I'm thinking about putting Iridium spark plugs into my KAWASAKI FX730V engine
Use iridium spark plugs?
  • Use iridium spark plugs and change idle speeds.
    Votes: 0 0.0%
  • Use iridium spark plugs and change gas grade.
    Votes: 0 0.0%
  • Total voters
    10
Ghenghis73
  • / I'm thinking about putting Iridium spark plugs into my KAWASAKI FX730V engine
Will I have any problems if I switch to iridium Spark Plugs? Should I consider adjusting idle speeds, using regular gas instead of Premium gas, (my dealer insists on the use of premium gas with the copper core plugs), or anything else?:smile::smile::smile:
motoman
Genghis, Due respect, but those plugs are used in ultra hi po ,high compression engines. Why spend $8 per plug for engines that run at fast idle. Or are you pulling our leg? How "bout aviation gas?:laughing:
