Ignition onJDlx176
zook
I have a JD LX176 25yrs old. To start you must turn key on and off until the starter engages and the engine will fire. How do you correct and the best way to diagnos? Thanks,Zook
EngineMan
Renew the key switch........maybe....!
Check all you connections first. Make sure everyone is clean and tight. By all connections I mean everything, battery, solenoid, key switch, safety switches. Fuel solenoid if you have one, etc.
