Export thread
Ignition modules
#1
D
DeBe
This all started a few years ago when I realised a popular Atom ignition module was no longer produced. At $35 Australian I considered them expensive. Decided to reverse engineer one, & found that they could be built for around $6. They were sold originaly to replace ign points & condencer on small engines. A lot of coils since have this circuit built into them.MOD.0 CIRC.jpgMOD.1.jpgMOD.2.jpgMOD.3.jpgMOD.4.jpgMOD.5.jpgMOD.6.jpgMOD.7.jpgMOD.8.jpgMOD.9.jpg
#2
D
DeBe
More pictures of the construction.MOD.10.jpgMOD.11.jpgMOD.12.jpgMOD.13.jpgMOD.14.jpg
#3
D
DeBe
First picture is the Atom module I pulled apart to find the component values. The rest of the modules all do the same job. Also pic of the module on my Victa lawn mower.IGN MODULE ATOM.jpgIGN MODULE KAWASAKI.jpgIGN MODULE NOVA.jpgIGN MODULE VICTA.jpgIGN MODULE.STIHL.jpgATOM copy on VICTA.jpg
#4
D
DeBe
All these modules are polarity sensitive, if you don't get a good spark reverse the wiring. It depends on the polarity of the triggering pulse from the ignition coil. Some pictures of a Negative firing pulse on these modules.CRO.NOVA MOD.jpgCRO. KAWASAKI MOD.jpgCRO VICTA MOD.jpg
#5
D
DeBe
#6
D
DeBe
Use an old Kawasaki weed wacker as a tester for modules.MODULE TESTER.1.jpgMODULE TESTER.2.jpg
#7
B
Bicklebok
Cool! Good work!
