Idler Pulley Replacement - Wright Mower
2Peter119
Good Morning: The idler pulley on the hydraulic drive side of my Wright Sport X mower is fried. There is no manuf. data on the pulley which is 6" OD, 1.375" wide, 3/8" shaft size. The dia. of the flat belt surface is about 5.25". The pulley is held off the mounting bar by a sleeve which extends about 1/4" past the outer rim of the pulley. Any idea where I can find a new pulley. My mower is very well made and has held up well but for this particular part, I'm looking for something of maybe better quality then the original. The belt went along with the pulley and working in the confined space is not something I'd want to do on a regular basis. Thanks for the help - Al
