idle adjustment
DanaV
is there a way in can adjust the idle speed on my kohler 7000 series engine. This engine does not have a choke.
Thanks
BlazNT
Thanks
All engines have a choke. Even EFI has them. They go about it in different ways. You have an auto choke. When the engine is cold it engages and as the engine warms it disengages. EFI just throws more fuel through the injectors till warm.
Just be careful about playing with the idle speed, because there was issues with the early models that had the idle speed too low, and prevented the auto choke from opening properly causing rough running.
