I take it that Briggs and Stratton is Recommending the Synthetic 5W-30 am I correct?
RoofTopPigeon
  • / I take it that Briggs and Stratton is Recommending the Synthetic 5W-30 am I correct?
I take it that; Briggs and Stratton is
Recommending the
Synthetic 5W-30; am I correct?
as this chart was included in my owner's Manual to my mower
With the manual specifying the (2) stipulations Below:
1.)*Using an SAE-30 in outside temps. below 40ºF can result in hard Starting.
2.)*Using an 10W-30 in outside temps above 80ºF can result in increased oil consumption.
You have read your manual correctly.
SAE 30 oil , like any other liquid will get thicker as it gets colder and thinner as it gets hotter.
Too thick and you get too much resistance so it is harder to turn the engine over fast enough to start it.
At the other end it gets to thin to maintain a seal and gets burned or dribbles out past seals
mechanic mark
Absolutely correct, follow B&S engine manual recommendations.
BlazNT
I use synthetic so do not take this wrong. The picture they provided is incorrect. Any oil rated 5w30 will cover the same temperature ranges synthetic or not.
7394
I agree with that.
It doesn't matter if such and such grade of oil will cover the same range as synthetic, it is what they are recommending at this time, and any oil outside that recommendation can be grounds for voiding a warranty. It wasn't that long ago that Kohler didn't recommend the use of any synthetic, that when they did, it was only for use below 40 degrees F.
7394
I can remember back in late 90's when Harley Davidson would threaten the same thing. But only because they did not have their own Synthetic oil to sell.. That changed quick tho.
