i have an 1984 mtd yardman start issue
cubbrute1440
hi i was trying to start this tractor im rebuilding and it was cranking and then just stopped. its not the motor that spins fine but i think its the starter. i turn the key the amp gauge moves but not even a click is heard. i dont know what it is but before i spend 75 bucks on a starter maybe some one knows something
The first thing I would do is check the battery and all connections. Make sure that the battery voltage is a minimum of 12.6V and all connects between the battery, solenoid and starter are tight and clean. Don't forget the ground connection to the frame.
cubbrute1440
but if the grounds wernt good how would the voltage meter work
If you have a bad or intermittent ground contact, the amp meter would jump, then read zero. Plus you are only reading voltage across the battery.
cubbrute1440
ok everything looks fine the only way to spin the starter is to hook a negative up to battery and positive right on to starter but it archs good and jumpers get hot
Ok, sounds good, let's find the problem. Here's a sequence to see where we are losing power.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
SeniorCitizen
Being a 1984 it could very well have a bad starter but to possibly save the 75 bucks for something more fun try this first.
Make certain the starter pinion gear isn't stuck in the flywheel. If that all looks good try jumping the starter directly from a known good battery with jumper cables.
