jekjr
- Jan 3, 2013
- 1,969
The fact is, there's very little difference between different brands of motor oil. The brand of motor oil matters little, but its viscosity grade (10W-30, for example) which is important. Use only what the owner manual specifies. Using the wrong [viscosity] oil can lead to reduced lubrication and shorter engine life. If the manual says or calls to use synthetic oil, do so if not it's your choice. Mobil1, Amsoil, Valvoline, SynPower, Shell Rotella and all the rest of the synthetic motor oils have too meet and exceed the same specifications to get that little (API Logo) on the bottle so use what you want.
Does the generic looking stuff Weal-mart sells carry that logo?
I have seen people run that stuff in lots of equipment and it looked like they did fine with it. I even ran it in a generator back after Hurricane Ivan out of necessity cause that was all I had.
