Ok, I got my mom's mower since she doesn't need it anymore, and it has been sitting for about 2 years. I cannot get the thing to do anything. I have a good battery, I took the starter off and it spins freely, when tested with battery cables. I replaced the solenoid (p/n 862-1211-211-16) and verified the wires were going to it correctly. The mower will not do anything because when I turn the key, the fuse in the back blows. I also replaced the ignition switch. The mower model number is 13AM762F065, under that, 183629, Bolens by MTD. Does anyone know what else it could be, and what could be causing the fuse to blow??? I have downloaded the Professional Shop Manual, but I cannot find anything in there so far, that would lead me in the right direction. Any and all help would be greatly appreciated with this. Thank you
