I'm wondering if anyone on these forums has owned a ZTR with the EZT trannies and has had to have one repaired or replaced. If so, how many hours of service did the ZTR have on it, how large of yard(s) were mowed with it weekly and how much did the repair/replacement cost. Many users that are mowing 4-5 acres weekly(and in some cases mowing commercially with even heavier usage) consider buying or will buy a ZTR with the EZT because they are less expensive than those with ZT-2800, ZT-3200, ZT-3400 or ZT-5400 HydroGear trannies. My understanding is that the EZT is designed for "light homeowner" usage(< 1-2 acres weekly) and myself and other users discourage buying a ZTR with EZT's if you plan on mowing more than that. I'd be the last to recommend spending more money needlessly, so I'm hoping that this question may draw out some replies from users that have owned ZTR's with the EZT that will either support or dispute the ability of the EZT to handle heavy demand usage.
DJ you know how I feel about the EZT. :thumbdown: I will say there a good unit for what they were designed for and that's a real light duty application. They need to be in a mower or matched to a mower weighing like 5 to 600lbs and no more, there GVWR is like 900 lbs I believe and with 10cc pumps and motors. So if your looking for any type of performance or longevity out of the unit you wont get it with the EZT unless your mowing a nice half or three quarter acre lawn once a week.
While you give the the thumbs down, I do feel better in that I mow 1/2 of flat lawn with a 501lb Raptor. I am a whopping 147lbs myself so unless I abuse the mower, it should take me into the condo years!
My timecutter Z480 is 7 years old and still no trouble. I got it used a few weeks ago and have used it every day. So can we call the zt-3400 junk because a lot of them have failed within 200 hours?
Ouch.....don't say that.....my ZTR has the ZT-3400's. It seems that if the ZTR is well maintained the EZT trannies can be pretty dependable!!
I agree with following oil/filter change recommendation on a new and leaving one be if it hasn't been changed for 300 hours.I have mixed feelings about changing the oil in a EZT.
Remember the ford transmissions back in the 70s and 80s they would work good until you changed the fluid and filter then they would just stop working.
So my thinking is if you get a used one with like over 300 hours just leave it be.
If you buy new then change the oil to a good quality oil.
I do clean the little sponge like filter on top of the breather hose.
I keep them clean and look for leaks at the start of every day
People like to mess with the RPMs to get more blade or ground speed. The ezt is only rated for 3800 max RPMs and no lower then 1800 RPMs
Driving the mower at a idle will tear any hydro up.
I agree with following oil/filter change recommendation on a new and leaving one be if it hasn't been changed for 300 hours. But now you've got "me" worried:0( When getting my ZTR out or storing it(transport to/from mowing....no blades engaged), I drive it with the throttle at idle all the time(well over the last 55 hours since I bought it). Am I potentially "damaging" my hydro transaxles(ZT-3400's)????? If so I'll correct that bad habit immediately!!!!!! And hope I haven't done any harm already!!!
When you are transporting at a idle do the hydros make noise?
Everything on a mower is Designed to operate with the throttle on fast even the engine.
The engine gets it's max air flow for cooling at full throttle.
Even a engine in a vehicle gets hotter at a idle then at normal driving RPMs.
One of the big reasons we now use electric fans. And performance engines use electric water pumps.
The hydros seem to have a louder "whirring" sound than when mowing at full throttle. I guess you could say they are "noisier', but I haven't noticed any "change" in the sound from when I did it with 0.5 hours on it the first time I used it. Maybe that means I haven't damaged the hydros yet.......I hope:0) Makes sense though(especially about the air-cooled engine needing maximum air circulation when under any load) and I guess I just got a much needed Lawn Mower 101. I am going to discontinue having the throttle at anything less than 1/2 throttle when starting or warming up and 3/4 throttle when engaging/dis-engaging the PTO. Anytime the "ZTR is moving" the engine will be at full throttle henceforth!!!! THANKS BUNCHES for catching that and giving me advice that may very well prevent me from damaging my Gravely!!!!!!!!!!
I do not know if engaging the pto at half or full does any harm or good. I try and engage at half or less but sometimes I get in a hurry and engage at full. Don't tell my wife.
If that becomes their new standard I won't be buying another toro. They don't have that problem now so what's the issue.I have a zmaster with a ton of hours it has a small leak in a hose. Really I don't believe a non serviceable system would hold up to the 3k hour mark. in a year I may add 1/2 a quart of oil. I'm not buying any new mowers this year . So have a year to see what happens.So what do I see for the latest Toro Hydro Gear ZT trannies, Not serviceable. They claim it helps to not have as many potential leak points at hose ends etc, & allows the commercial user to have one less thing to deal with.. :confused2:
I prefer the serviceability . seems to be a better system with pumps and drive motors separate. And a lot stronger .
Cheaper to make .So they can make more $$ .Would be my thoughts on it.
That to me is puzzling, why would some be serviceable (Oil & filter change), & others sealed ? Both Hydro-Gear units.
They are non servicable because the sealing is very good and the units are made in a sterile clean room.
Clowns drain the oil find an old grubby funnel then proceed to fill the box with dirt , dust & grass clippings.
When I do one of these , I clean every thing in an ultrasound unit followed by either & blow dry.
They then go into the bathroom ( I work out of an old house) after I have hosed down the room & walls.
Dust down as low as 0.5 micron size will kill the unit in no time flat.
Well, this has certainly sparked some interesting posts.
And to Bert- I build Harley engines & trannies, by appt only.
And growing up as a Diesel mechanic with years in a machine shop, I don't think a EZT or EZ hydro pump would be very intimidating. You're not the only one that can turn a spanner, or has a "clean room" for assemblies.
:thumbsup: Not a parts changer, specialty is stroker engines, & putting 5 or 6 forward gears in old 4 speed H-D gearboxes. :wink:
I am sure that would be a popular mod.
While the very wide & flat torque curves means they can do without those extra cogs, it does make a big difference.
totally off topic by now but just out of interest, do you raise the final drive ?
Hello All,
I just joined this forum. I was looking for some info on Hydro Gear EZT transaxles.
I notice that this topic is not current, but about Hydro Gear transaxles.
I have a Troybuilt ZTM 50 " cut. When I bought this mower the left transaxle was never as strong as the
right one. I called Hydro Gear and was told if it worked it worked and that was it. I should have
insisted a new unit. Now with about 230 hours, the left unit quit pulling. I will try to repair
this unit if possible. A friend has called Hydro Gear about some differences in units and they just
give us get rid of this guy info. Call about the difference in a pair of transaxles and the guy said he
commented that one had a one inch shaft and the other had a 3/4 inch. Both had one inch. one had
the brake on opposite side. The web page states this can be move to the other side. We called and
asked about this and was told it was not advised. This is from Hydro Gear's service dept.
Personally I think the units are not well built and way to costly.
Hcube
Start with my son worked at Hydro-Gear and built the EZT and others. Yes they are built in a clean room. Here comes the bad part. They are shipped dry. The lawn mower manufacturer then adds oil to the unit. No clean room. They are mostly filled in a dirty manufacturing line. This is one of the reasons for EZT failures that I hear about on this and other forums. The other is they do not use the recommended oil to fill it with. John Deere is the worst of the offenders. They want to sell their oil and put it in instead. Hydro-Gear builds all their units with spects from Castrol 20w50 motor oil. If the manufacture uses that or at least 20w50 in a simi clean area then your EZT will last a long time. If not the failures will happen.
I love this forum We get to share all sorts of knowledge,
It is just Castrol 20w50 regular oil. You can waste your money on synthetic if want (I did) but it is not necessary. I also poured my oil through a very fine paint strainer.
Boobala, Thank you
Boo,
Have any experience in having several Hydro Gear wheel motors in the shop at the same time? Thus able to state if a 4400 has the same mounting points, rod lever points, etc. as a 2800, 3100 and 3400?
If you can verify these have the same outer mounting points. I'm installing a pair of 4400s on a Raptor SD or go thru the set of 2800s and upgrade them to 4400s.
Thanks in advance,
Max
No reason to get worked up over cuttin' grass. I'm just thinking that heavy use (extreme heat) & contamination without an easy way to change fluid & filter is what makes the ezt "light duty". They seem to be giving a lot of folks good service.
A '69 Hemi Superbee could test a Dana 60 rear end, but a slant 6 Valiant didn't need one. Some guys need a 1hp bandsaw and some only 1/2hp. On & on..
I have yet to have any issues with my Husqvarna Z4217,but I keep reading low engine rpm will damage the EZTs. While I never mow at less than at near or at full throttle,what happens when lower rpm is used? What gets damaged and how and why is what I was wondering. Just something I was curious about. So much great knowledge here! TIA!
