Export thread
hydro gearbox
#1
S
sss
i have an mtd tractor with hydro gearbox it tend to make this weird noise especially when you accelerate hard if a (mower can acellerate)(more pushing the pedal streigh down from standstill) and towing when i looked there is a mini tank with fluid in and it looks rarther low. Does anyone know weather you need to change hydro gearbox fluid ? if so what do you need to use many thanks
#2
pugaltitude
pugaltitude
Depending on model of gearbox.
Some are sealed for life, others you can just top up and some you can replace the oil.
Some transmissions take 10/40 oil others take 5/50 fully synthetic.
All depends on the model of box.
