hydro gear zt 2200 repairs?
krismanten
is there any way to repair the 2200 transaxles once they stop pulling? or is this a lost cause?
dfbroxy
Yes, Google How to rebuild zt 2200. There is a great vidio on how to do it. Watch it and decide if you want to rebuild or just buy a new one.
Some times you can get a bit more life out of them by draining the oil and refilling with something a bit thicker.
IF they are worn out, they should work fine first off then get weaker as they heat up ( usually noisier as well )
If they just stopped working without warning then suspect a broken belt, broken pulley or stuck bypass valve.
Hydro gear do sell rebuild kits which will work out about 1/2 to 2/3 the price of replacement.
Just remember they are made is dust free sterile enviroment and you need to do the same.
I use the bathroom in the workshop, spray the walls down and keep the trannies covered with a damp rag.
This is after washing degreasing washing again, soda blasting & rinsing off the outside
krismanten
is there anyway of switching to a 2800 tranny if a 2200 ever does go out?
BlazNT
With a little work you can. I know the brake is different. But the biggest thing is you will have to change both at the same time.
