Hydro Gear Oil filler adapter
phoneman44
I am trying to locate an adapter to screw into the drain plug port on a Hydro-Gear to refill with 2 quarts of gear oil after draining and changing the gear oil.
I am aware of the Hydro-Gear web site that offers the entire kit with filters and oil, but I prefer to use my own filters and oil choices for my zero-turn Gravely.
The Hydro-Gear model number is 72050 ZM-KEEE-3LEG-3ALX.
Thanks to any and all advice that can be provided.
hlw49
You drain the hydro by taking the filter off and fill it like MParr said. Some mowers have an expansion tank or tanks under the seats when you take the side plug out you can fill through the tank.
MParr
True! I completely forgot to mention the expansion tanks.
Some mowers don’t have expansion tanks. They have long vent hoses that are plumbed into the top plug. Just remove that hose and fitting and fill there.
Allow a little over 2 quarts of oil for each hydro. A 5 Qt. jug will give you plenty with a little left over.
phoneman44
Thanks for all who replied to me.
I have another question relating to the same hydro gear: The O-ring Hydro gear part #52250 what is the recommended torque value for reinstalling this O-ring. I have at least one side that is leaking just a bit. According to the exploded picture of the gear itself this is #132 O-Ring size description -137. 103 X 2.050.
Thanks
I also found a part for filling the Hydro-Gear pumps and I am attaching it for everyone to see. I ordered it from hydro pumps parts.com
The charge pump (Georotor) cover screws are tighten to 100 – 130 lb-in (11.3 - 14.7 Nm). Now these covers can warp and leak per the info I was given as few years ago.
Also hopefully you mark it before removal as it is directional on these ZT-2800's
Also if you are a shop you would be better off ordering a pack of the dash 137 o-rings as the last pack I brought was $1.86 for 10 of course shipping has to be added. But I normal am ordering other parts at the same time so costs less per item. Also if you screw up an o-ring it less costly to replace.
