Hydro Gear Manual
Does anyone know where I can download a service manual for a Hydro Gear 312-0800. Can't find one for a 312 just for the 310. I have the parts breakdown, but would like a service manual before I tear this one apart. Thanks in advance. Rivets
IlEngine, when I only that site I am only getting a parts manual, no service manual shows up. Am I doing something wrong?
I posted that this morning then realized that you where looking for the service manual. I can't find a manual for the 12 either, just the 10. Hydrogear site doesn't even show a manual for that tranny. I also checked my old hydrogear paper manuals but didn't have that one either. I am wondering if they are using the 10 manual for the 12 also. From what I could find it is a discontinued tranny out of a Simplicity.
About the only thing that goes wrong other than an occasional seal leaking is the motor, center section gets scored and basically destroys the main parts of the tranny. About the only thing that you can salvage most of the time is the differential and the case. And I have popped the threads in the case when retorquing the center section.
I thought the same thing, until I noticed that the 310 had split axles and the 312 has a one piece axle/differential. Believe it or not, but the axle broke, it did not twist, but had a linear split/crack and just finally broke. I am replacing the axle, bearings and seals, everything else looks good. Has you know, having a service manual on hand makes it easier to fix dumb mistakes when your have to guess on reassembly. Guess I'll have to rely on a 310 and hope nothing weird turns up. That's why they call me a grease monkey. Thanks IlEngine for trying.
Very interesting. Part number I was going to order was #70258 at a price of $225.00 from my distributor. Before ordering I will give them a call and see if the axle is still available. Thanks for the tip.
My distributor shows the 50079 in stock for $50.00 and the 50080 for $43.34 but none in stock at this time.
I'll Let you know what happens. I need the left axle, which is 50080. See what happens.
IlEngine, leaving for work in 10 minutes, but just wondering where you got that second number, 1715764. Will be calling distributor and need to explain.
Just got off the phone with my distributor and the part number 50080 is the correct one for my unit. Cost through my guys is $42.50 I found where you got that number, have to learn to read better. I'll let you know what happens when the parts come in. Thanks again for you help.
