- Nov 29, 2014
- 65
- 24,995
Having all sorts of fun & games trying to do an oil & filter change on the hydros .
The filters have a 9/16 hex on them for a socket , well & good but one just twisted off and the other looks like it is going to do the same thing
Did the first one cold so tried the second ona hot hydro bit still does not look like budging
Is there some trick to it ?
I really do not want to be laying under the mower chopping out filter elements with 1.5 Litres of hot oil above it .
Should I do this a lot more frequently than 500 hrs to prevent them fusing into the case ?
Did Toro put some sort of sealant on them from the factory ( this is the first change AFAIK )
