Hustler Fastrak Trans Issue
DANLODE
Had a hydraulic leak from cover of transmission by hydraulic pump. Fixed leak, pulled plug on top of trans and filled reservoir. Bled system as per manual. No motion on transmission. I am assuming its an air in system issue. Any ideas?
take it back off and turn it 180 it is a charge kit and has directional marks on it turn it around should be all good..
You never said but thinking this is a transaxle with filters did you fill the filters up as well. Let us know what u find.
