panshovelmike
- Jun 22, 2014
- 2
I recently purchased a non-running Hustler FasTrak 48 mower with a Kawasaki fx730v engine. I'm trying to get the mower to start, and need some assistance. I'm pretty experienced at working on motorcycles and cars so I have a pretty good basic understanding of the fundamentals.
I have the owners manual and following the instructions for start procedure in manual, the mower will not crank. When I turn the key, I hear a faint click from the motor compartment. I do not know if this click comes from the starter solenoid on the side of the starter... from what I've read, the click may be the fuel solenoid. Testing with a multimeter, I get 12.9 v at battery, and the same voltage at the positive terminal of the solenoid attached to the starter. When I apply battery voltage directly to the other "starter" terminal of that solenoid, I hear a whirring noise that I believe is the starter spinning but not popping out or engaging... it does not turn the motor over.
Now in examining the mower, I have found a second (disconnected) solenoid on the right side of the mower near the battery compartment. This solenoid looks like a starter solenoid, and it's what I find in google when searching for a starter solenoid for my model of mower. I will attach to this post a photo diagram illustrating location of other solenoid, and google picture of what the solenoid looks at. Now this second solenoid appears to not be connected. It has 1 skinny "trigger" wire going to it from the mower's harness, however nothing is attached to it on the 2 large lugs (where typically you'd have 1 fat wire going to battery and another fat wire going to starter). I can't find a wiring diagram that will explain this second solenoid to me or what it's purpose is.
Anyone have any ideas or input as to what my starting problem may be, and wether or not it is related to this unhooked solenoid I've found? Thanks in advance for any input, much appreciated.
