Hello Woody..I may have the same fastrac you have. Mine is a 2012 model. I also have an older scotts mower that started having the same problems you are describing. I finally got it going by blowing air into the fuel line from the fuel filter back out the gas tank. It was getting small pieces of stuff sucked into the fuel line in the tank. My fastrac has two fuel tanks with the switch mounted behind the seat. You might try cleaning out the fuel line. That's where I would start. Good luck.
