Engine Husqvarna zero turn Briggs V-Twin Intek Engine can't get pan off
klein
  • / Husqvarna zero turn Briggs V-Twin Intek Engine can't get pan off
good day
i'm working on a Briggs V-Twin Intek Engine, i have all the bolts out and have separated oil pan from the main housing by about 1 1/2 inches. main shaft is pulling out from the top.
the oil pan turns on the crank shaft but won't pull out, i have used a block of wood and ball peen on the crank shaft and it still isn't budging, is heat my answer ?
i believe it had a bad cam lobe, then it broke both connecting rods.
