Family member has the YTH2348 with a Briggs/Stratton Intek XRD 23HP motor.
It runs fine,but the weird thing is.....when you move the lever forward that should make it idle faster,it wants to cut off as if the lever was in the lower position. If I put the lever into the lower position,it wants to idle high. Acts like something is backwards,but I have checked cables,springs,checked governor, and even checked the carb and it all looks ok.
I tried to find a picture of the bracket that has the springs attached just to make sure something hasn't gone wrong,but can only find a picture of the bracket with nothing attached.
I'm at a loss and was wondering if you guys had any suggestions as to what it may be.
