Husqvarna YTH22V46 Rear Wheel Axle Seal leaking
eastfork2
Husqvarna YTH22V46 Rear Wheel Axle Seal leaking.
Appears to have the Tuff Torq K46 series transaxle. Seal PN 187T0134280.
eastfork2
Thank you StarTech, My Husqvarna is a recent hand me down from family. Normally left outside (with cover on most of time).
YTH22V46-960450041 SN: 030413A015829, ~2012 or so.
Transaxle: Tufftorq KBT (426120)
Not sure I have correct PT Manual but snip1 is from it. I assume pt72 in snip 2 is seal that is leaking. I do not have this apart yet and have only removed outer rubber/plastic cap to expose pt33, 205. Is this straight forward, pull seal with screw or hook puller and press/hammer new one in/done?
Usually the hardest part is getting the wheel off. They tend get stuck on the axles. But it is fairly simple to remove and replace as you got the general idea as it is a rubber coated seal when putting seal on warp the axle with electrical tape so you don't the inner seal lip as slide it on pass the axle keyway.
eastfork2
Seals are ordered, will post results when complete or cry for help. Thanks!
